A new beta of Sunlite Suite 2 is available to download ...
https://www.nicolaudie.com/en-gb/download.htm
Updates:
- a change from Direct X to VLC media handling libraries.
- fixed problem with pan and tilt on multi-beam lights.
Sunlite Suite 2 Beta 13th June 2016
- New Forumor
Re: Sunlite Suite 2 Beta 13th June 2016
I am using what says is the current beta. When I run the application, it gives a date of May 30, 2016.
Have had no problems with the current install until today. Today I got a MIDICon controller. When you load the controller into the console window, if the Sunlite Suite 2 program loses focus in Windows, it will stop responding. I verified it happened with or without the console connected. Simply having the console window open inside Sunlite Suite 2 caused the problem.
- New Forumor
Correction: when you minimize the window, not when it loses focus.
