Hello Everbody.
In some cases I work with two differents laptops and Sunlite Suite2.
On one Laptop I make the config for a show and on the other one I control the show...
It´s no problem to export the show from one laptop and import it on the other one.
But my setup for the USB/MIDI-Console is always empty and I have to create a new one.
I haven´t found a solution to copy the config settings for my console from one laptop to the other.
Is there a way to do this in a fast an easy way?
Thank you very much and have a nice day.
heelius
Export Console Settings + Show
Re: Export Console Settings + Show
When you import a backuped show, SS2 ask you if you want to use the default console or the one of the imported show... just select "Show File".
It works for me without problem as i work on my show offline and import it on another computer for the live show.
Gaël Rambaud
Light Designer and Technician
*** Freelance ***
gael (@) bloc-company.com
http://www.bloc-company.com
*** Freelance ***
- Contact:
The midi configuration file of your show is located :
C:\SunliteSuite2\_DataLight\YOURSHOW\#COMMONFILE#\MidiCommand.xml
So, as explained by Gaël, if you import your show, and select "Show file" for the midi console data, you should bring them back in the same time. No additionnal tasks are required.
Sylvain
Sylvain
- Interface Economy Class
- @MixLightEvent (31) France
