[BUG] [Reproducible] - Matrix color effects with color palette = display bug
Superbaloo8
Post by Superbaloo8 »
There is a bug in the latest beta (29/01/2016) where we want to use palette to define matrix effect on a group rect.
Pre-requisite
  • Have enough fixture to play with matrix effect
  • Have color palette created
Scenario
  • Create a new switch
  • Edit this switch, and create a group rect of your fixture to apply matrix creation
  • On Matrix creation, choose the effect you want, and then, try to change the first color by one coming from your palette color
2016-03-26 02_55_32-Nouvelle notification.png (251.11 KiB) Viewed 9178 times
Expacted behavior:
Have the color palette correctly applied, and saw its color
Actual result:
The palette is well taken into account, but the feedback is not visible on the several square of color, and the previsualisation is so not working. Overall, even if its display black when setting the matrix, the result is working correctly.
Video on youtube showing the issue:
https://youtu.be/dssVR-0Uzws
Sylvain
  • Interface Economy Class
LightJockey
  • @MixLightEvent (31) France
Superbaloo8
Re: [BUG] Matrix color effects with color palette = display bug
Additionnal information:
This bug only appear for following palette type:
- Palette Generic per fixture Type
- Palette per fixture Type
Tested on another PC, same issue exists
LightJockey
Re: [BUG] [Reproducible] - Matrix color effects with color palette = display bug
Hi Sylvain,
Thank you for reporting this usability issue. I have been able to replicate it (see attached) in the latest Beta.
It would be better if the icon displayed in the Color box (left) be the same as that shown to be the Colours palette window (right). Instead it shows a generic, black palette icon.
I will report this to the developer.
Screen Shot 2016-04-01 at 16.44.29.png (235.67 KiB) Viewed 9145 times
