ESA Pro Feb 11 2015 using with STICK-DE3
I have a question regarding the timeline. For a scene I want a simple RGB color changing with fade. So I added each color as static color with 50% fade. The duration of each is 20s because of the timeline limit of 60s.
But the default time with the DE3 is therefore 60s too only, what's to fast.
--> Is there a possibility to extend the time so the default setting isn't running through the colors within 60s only?
Thomas
extending Timeline
Re: extending Timeline
Hi Thomas,
You are not limited to 60 secs, if you click the 'Size' button (clock symbol with red arrows) you can set the timeline of the scene to whatever you want.
Image attached for reference.
Hope that helps.
Hope that helps.
- Screen Shot 2015-09-03 at 15.32.37.png (33.3 KiB) Viewed 10043 times
