FPS speed / graphics
spirit
Post by spirit »
Hi all
maby many poeple allready ask this but i could not find it.
but i'm getting a realy low FPS its allways at 21
if i turn resolution low its still at 21.
if i turn it to Maximum its 21.
but the point is when i enable Shadows the software goes all over the place.
when i change DMX values it drops to 8FPS
its not the biggest problem to run without shadows.
but what type of pc do you need to run this?
it uses more then Crysis 1 and witcher 1 and these are demanding games.
specs:
Mobo: corshair V formula-z
Cpu : AMD-6100 (default 3.1ghz x 6, current 4.0ghz x 6)
Ram : 2x 4Gb @ 2100 mhz
Videocard : 1x Nvidia 770 GTX 4Gb @ 1080mhz (gigibyte vesion)
freestyler as DMXSoftware.
greetz, Spirit
Ben
Re: FPS speed / graphics
Post by Ben »
Hi Spirit,
Can you tell me as this always happened when using the software or changed between versions? 21 fps is pretty good, as the visualiser is processing a lot of data in real time.
Kind regards,
spirit
Post by spirit »
hi and thanks for the reply
i use version 14.1212.10546.646 (12-12-2014)
its just the version i use that comes with Freestyler + a MOD (otherwise it stays in offline mode)
and its a small stage.
59 parcans which half is mirrored so only 29 dmx channels.
6 robe colorspots 575
6 robe robin 600
stage made out of a cube.
and some other objects.
so there is nothing you can do to increase the frame rate?
stage 2.gif (101.26 KiB) Viewed 9811 times
