Stick KE1 IP address change
ShaferCustoms
Post by ShaferCustoms » Thu Jun 04, 2015 6:32 pm
How do you change the IP address of the Stick-KE1?
I have access via Hardware Manager via USB
Can not see method to change IP - to what I want or DHCP?
Please advise
Dave
Ben
Re: Stick KE1 IP address change
Post by Ben » Fri Jun 05, 2015 8:45 am
Hi Dave,
Open the HardwareManger.exe found in the ESA Pro or ESA2 program directory. Click on your device icon, scroll down to the bottom of the list of icons that appear in the next column and select the last one called 'Ethernet'.
Here you'll find the options to change the IP address and to select DHCP.
Hope that helps
