Help, I have a problem with a group fixtures
Shask
Post by Shask »
My groups and channels
Grupos luminarias2.png (186.76 KiB) Viewed 8593 times
Hello everyone, I have a show with 30 beams of the same make and model. The other day I had to update my library for a fault that was. After doing so, I returned to configure the buttons recreate luminaire groups and it seemed that all was well. The problem is that when I go to program a button now have to go channel by channel luminaire to luminaire and one at even though I have re-created groups. No longer let me work in groups and are very uncomfortable and heavy when there are so many lights. What solution can I do other than re-create the show from 0?
Thank you very much!!
Hola a todos, tengo un show con 30 beams de la misma marca y modelo. El otro día tuve que actualizar la librería por unos fallos que había, volví a configurar los botones, volver a crear los grupos de luminarias y parecía que todo iba bien. El problema es que cuando voy a programar un botón ahora tengo que ir canal por canal y luminaria a luminaria de uno en uno a pesar de que he vuelto a crear los grupos. Ya no me deja trabajar por grupos y es muy incómodo y pesado cuando hay tantas luminarias. ¿Qué solución puedo hacer que no sea volver a crear el show desde 0?
Gracias!!
Ben
Re: Help, I have a problem with a group fixtures
Post by Ben »
Hi there,
If you email me over your showfile I can take a look and see what the problem is.
Kind regards
