When I make a new scene using "as you see now", the dial settings (size/phase/dim/speed) for each of the included switches is reset to default, so the scene looks nothing like "as I see now"
my workflow is to make a basic switch and then create a bunch of varieties based on turning those knobs. much faster than editing each phase within the effects of each switch.
fortunately this does not happen with cycles, so I am not completely stuck. but I would like to be able to program with scenes. is there a workaround for this?
new scene omits phase/size/dim/speed settings from switches
Re: new scene omits phase/size/dim/speed settings from switc
Hi James,
When you create a scene 'as you see now' this will include lots of different buttons all with different Speed/Dimmer/Phase/Size values. What we do is embed all the changes and values into the new scene. Your scene should look exactly the same as what you set previously, if it doesn't please email us over your showfile with all the details and we can take a look.
