Pause Switch/Scene
Posted: Fri May 08, 2015 3:53 pm
by fedisunlite
Goodmorning, I am a new user, from Daslight DVC 2, I have a question:
There is a "pause button" (like DVC) or similar thing for switch and/or scene? Exemple: I create a switch/scene with lights moviments and I want pause and resume this switch/scene. Thanks all
Re: Pause Switch/Scene
Posted: Fri May 15, 2015 8:20 am
by Ben
Hi there,
Yes this is a new feature that has been added to Sunlite. To achieve this you will need to load up a console in Sunlite Suite 2, shift right click the button that you want to pause and select 'button in pause mode' from the drop down menu.
Two things to note, a) this feature is only available in Sunlight Suite 2 versions Feb 2015 and above. b) If the button you want to pause is not included in a compression, you won't see the pause icon on the button. This is a bug and will be fixed in the next release of Sunlte Suite 2 next week.
Hope that helps.
Posted: Fri May 15, 2015 10:20 am
by fedisunlite
Thanks Ben! And.... is very necessary a load up a console?
Posted: Mon May 18, 2015 11:24 am
by Ben
I've just been doing some testing and there is away to do it without the need to load a console. There is a new feature where you can assign a mouse shortcut to the pause/play option.
If you goto 'Software Preferences' and click on 'Mouse action' you can assign the 'Play/Pause button sequence' from the drop down lists to a mouse action.
Posted: Mon May 18, 2015 3:10 pm
by fedisunlite
Ben wrote: If you goto 'Software Preferences' and click on 'Mouse action' you can assign the 'Play/Pause button sequence' from the drop down lists to a mouse action.
Gorgeous! It was just what I was looking for!!! Thanks Ben!!!!
I like more and more Sunlite Suite.... great job guys!!
