Switchting different Scenes / GA2
Posted: Tue Mar 31, 2015 3:40 pm
Hello Nicolaudie Team,
I just watched some videos about your STICK Series wallmounted DMX controllers. Now I've got a question, if your controller can meet my requirements.
As I know I can't test this bymyself because I need to be conntected to an actual interface to check this with the downloadable software.
I want to use a "GA2" interface to controll the following ligthning equipment:
3x DMX RGB LED floodlights and 1x DMX 12-Channel Dimmer
The important thing on this is that I can do the following things with your product:
1> choose every single DMX channel of the dimmer and change the dimming value from 0 to 100%
2> chose every single DMX channel of the RGB floodlights an change dimming and color
The very important thing is that I can switch the scences without overwriting the current set of dim and color.
For example User clicks to scene 1 with all the LED floodlights and dims them to 100% and red. After that to switch the dim of channel 12 he has to
change to scene 2. Is it possible that the settings of scene 1 are still active or are the LED floodlights turn off after switching to scene 2.
