Sunlite Suite 2 13th February 2015
Posted: Fri Oct 31, 2014 1:59 pm
There's a new version of Sunlite Suite 2 on the website including various new console features. For those who have just upgraded from a previous beta, the changes include minor bug fixes.
Here's an overview of what's changed since the previous official version...
_______________________________________________________________________________
********FIXED BUGS********
There was no midi feedback on page change
Multi-dimmer problem. If you had a dimmer channel affecting 1 beam and a master dimmer channel affecting all beams, the master dimmer channel didn't affect the brightness of the fixtures in the fixture preview.
if you had the first item of a compression selected and you sent the ‘previous button of selected page’ command, the software would select the first button of the previous compression instead of the last
Easy Show->when you expanded a block by stretching the front, the end point of the dimming curve was moved. This caused a crash on playback.
console builder was not loading CCD info from consoles embedded in the showfile
disable arrow key control of the XY grid if the easy step window is in focus
Console right text label right align didn't work properly
if you change the patch and then create a new show, the patch change was still included in the new show
when you double click a tab, the tab is undocked, the window shrinks to around 4x4 pixels and the window moves to the top left of the screen.
console builder->save opens SaveAs window
it should not be possible to assign the same DMX input universe to more than 1 connector/device. For example, at the moment you can assign DMX Input 1 to all 3 connectors on the Suite2-FC. If a user makes this, none will work.
if there was an Easy Show 'open' and 'jump to break point' trigger in the same switch, the jump to break point didn't work
console builder-> if you tried to load a console from the recent files list which didn't exist, the software crashed
now possible to write up to 10 areas to the STICK-DE3
********NEW FEATURES********
cycle auto save (enabled by default)
open a console file from the show folder in the console builder
play BPM in editor when you press play in easytime or easystep
it's now possible to tap a BPM without opening and closing the audio analyzer first
send all ‘velocity sent when control is off’ values at the very start of the software (before sending defaults to the console)
possibility to select a window from the console
console->possibility to open the properties dialog when a console pairing is made (optional)
write the name of the console file in the console tab
possibility to make a pause of the sequence button (normal or bpm mode)
multibeam pan/tilt
possibility to select compression names in the console editor
after creating a new show, open page wizard automatically
relative mode with joystick
show the fixture mode on the patch print
in auto mode, arrange IP interfaces in IP address order instead of serial number order
filter MIDI devices for each console
add "send to easyremote" option to console setup
New virtual selector console function so 1 control can be paired with several commands depending on the value of the virtual selector
