Hello
Since a few week, i have an issue with to find controllers from my Ipad connected on the same Wifi that Sunlite Suite 2.
Do you have an idea to resolve my issue ? How can i check if the console communcate, which port ? ... ?
I made a test with another Ipad, same issue?
I remove and re install Sunlite to new folder.
Firewall is disable. Nothing had changed from my computer, maybe Microsoft Patch
Regards
Easy Remote : controllers unavailable
Re: Easy Remote : controllers unavailable
The communication works on port 2430 and 2431. We found a problem with networks on the 10.xxx.xxx.xxx IP address range which will be solved in the next Easy Remote update. Other than this, we are not aware of any communication problems.
Having the same issue here. Have been unable to get the EasyRemote app to find any consoles for some time now.
my network local network range is 2.xxx.xxx.xxx . Tried to setup a 10.xxx.xxxx.xxx network to see if it would work but no luck.
running Sunlite Suite 2 (September 23, 2014) on a Sony Vaio with Windows 8.1 Pro and attempted EasyRemote (May 15, 2014) on both a iPad mini running iOS 7.1.2 and also on a iPhone 6 running iOS 8.0.2
You cannot use 2.xxx.xxx.xxx or 10.xxx.xxx.xxx with the current version. This will be corrected in the next update.
