i purchased some 12 cree LEDs moving heads.
the dmx manual assignments says that pan and tilt are channels 7 and 8
I created my fixture config assigning all correct channels with the scan library editor
Starting a new project with these fixtures patched I noticed that pan and tilt are reversed.
The manufacturer says that the channels are correct, in the fixture control panel the pan and tilt are not reversed.
regards
Problem with Cree LED Moving head
- Junior Forumor
Re: Problem with Cree LED Moving head
I guess this is a problem with the fixture profile. Open the profile in the scan library editor and swap the pan and tilt channels
