USB connection doesn't work on 1 july release
Posted: Sat Aug 10, 2013 4:19 pm
Hi Simon,
This time I have an even bigger issue.
I installed the software on my win7-64 laptop which my controller is connected.
If I start up the ‘tool’ software, I can connect and update to firmware 1.20
However, if I start up the 1 july suite, then I can’t connect to the controller.
I tried to uninstall usb drivers and reinstall, but nothing worked.
I also installed an older suite2 version, and there I had connection, but because the controller is now updated, the older suite soft doesn’t work with it .
Is there any logs I can give to you?
To me it seems that there is something wrong with usb connection with suite2 software.
Can you check this?
Can you check this?
