I bought a STICK KE1 and ASUS K56C windows 8 Notebook.
I found out USB hot plug Stick KE1 that show driver break.(see attached file)
Could you confirm how I solve the issue?
Thanks & Best Regards,
Albert Chen
Stick-KE1 driver issue for Win8
- Stick-KE1 driver issue for Win8.png (56.58 KiB) Viewed 14602 times
Re: Stick-KE1 driver issue for Win8
Make sure you're running atleast the April 2013 version of ESAPro which will install the Win8 driver.
I installed ESA Pro version:2013/04/26, but it still appear the same issue.
I'm not sure why it would do this, it's working on all our Win8 machines. Try uninstalling and then re-installing the driver (the file is called 'SiudiDriverV2.exe')
I already confirm 'SiudiDriverV2.exe' driver to execute OK for Windows 8.
Thank you for Help.
Albert Chen
Thank you for Help.
Albert Chen
