Dear SL Community,
I have a serious problem with installing my SIUDI 6C / SL512BC interface. Althoug I've installed the correct driver (Win7 recognises it as Intelligent USB Interface, 6C, 64bit), the lightnings that my show has to control run with a delay between command and execution. The red green and yellow LEDs on the interface flash or are ON (as they should) but during the operation they go off and only the yellow LED is on. I can exclude that the interface is broken, because I've tested it and tried to run the show with an other one, but the same delay-problem occured. I can assume for sure, that the problem is caused by my computer.
I'm really desperate because I've tried all opinions that came to mind.
Please help me.
with kind regards
Thomas
P.S.: for your information I'm using USB 2.0, Sunlite Suite 2006
Siudi 6C Driver Problem with Win7/64bit
Re: Siudi 6C Driver Problem with Win7/64bit
Try the latest Sunlite Suite version and also try a different computer
Thank you for your quick answer! I'm using the latest version of SL and I've also tried to run the show on a different computer, but the same problem occurs. After a short time, the spots freeze, the LEDs on the interface go off and only the yellow one is on. After a few seconds the show runs on.
Thank you for your answer.
