i got a two problems with this version:
- rotary fader input doesn't work. all other faders gives feedback however the rotary doesn't.
It saves external changes in the background but doesn't display them on the ipad
- i tried to assign the color ball/ tan&tilt described in the manual, but i stuck at the point to right click. i tried it nearly an hour to connect the commands in the scene builder or on fixture pages.
i was unable to link them at all.
(linking the dimmerfader didn't work too)
regards
Easy Remote Bugs v 25.4.13
Re: Easy Remote Bugs v 25.4.13
Regarding the first issue, this is a bug in the EasyRemote app and will be fixed in the next app update soon.
Regarding the second issue:
-right click the color wheel on the console
-Click the 'General' tab
-Click the star and go to others->color mixing control command
-Select a fixture group, a color mixing switch, or leave on the default values to apply the wheel to the selected button
thank you!
helped a lot! got the color wheel connected
