white balancing or callibrating fixtures
69morpho
Post by 69morpho »
Hi there,
I am using 256 custom RGB fixtures for a large architectural installation. To get white each RGB channel has to be set at 255. Unfortunately this leads to an very uneven white. Some fixtures have a slightly red tint, some more blue, etc.
Is it possible to white balance or calibrate fixtures? I went into patch manager and the area window but I can't find any global setting where I can set a macro for each individual RGB fixture, eg. fixture 1 red to 95% max brightness to get the red tint out, meaning if I set red in that channel in the time line to 255 it only is 95% bright instead of the default 100% etc. I am basically tying to set a global max brightness for each individual channel...
Thanks for your help,
Erwin
Re: white balancing or callibrating fixtures
Hi Erwin
Unfortunately, there are no advanced color calibration options in ESA Pro at present.
