I think this is a bug:
I have a Setup of Pages (fixtures) in Sunlite Suite 2. Then i did some changes at the Fixture File.... Because i dont know a other way to refresh the page, i delete the page, and create it new by selecting the fixture file. I also select "Ad the device to masterPage".
If i have done this, i am not able to find the Fixture in the Fixtures Page....
If i close the Suite2 and restart it, then the fixture is visible in the FixturesPage, and i am able to move it on its place.
best regards
erich
Bug... Device not visible in Fixtures Window...
Re: Bug... Device not visible in Fixtures Window...
I'm not sure I have understood. For example...
-add a page with 4 generic moving heads
-modify the profile
-remove the moving head page
-create a new moving head page with 4 moving heads
-the page contains no fixtures when you go page settings->patch ??
-modify the profile
- Contact:
Hello Simon...
yes... nearly correct...
The New Device could found at this window after restart of software.
greez
Erich
this is right, but this is wrong...-add a page with 4 generic moving heads
-modify the profile of the Moving Heads
i talk abought the Fixtures window... the window you will see, if you click the Fixtures Button next right the "pages" Button... Thisfixtures page is displaying all devices of all pages, wich are atached to the master page. Here you are able to arange the fixtures and select them to create Buttons and more....-the page contains no fixtures when you go page settings->patch ??
greez
Erich
