Bugs in 2011/07 Beta
Posted: Mon Aug 22, 2011 7:45 pm
Good dayI
- have found that when having activated the Preset pane before exiting the edit switch buttons window will make both the x and y values reset to zero after editing the same switch again.
- I find the same "improper argument" problem i was having when adding points in an easytime x-y sequence with earlier versions of the software.
- Double-clicking a fader when editing x-y sequences resets it to zero, even if we are clicking the up and down arrows on the bottom and top of those faders.
- Assigning the "&" shortcut is not reflected in the buttons of any page. It will still be active, but the shortcut won't appear.[/list]
