can't drag Generic rgb fixtures to DMX universe
Morrell
Post by Morrell »
I am running a Slesa-U5 ver.1.6
Dell Latitude laptop
windows xp ver 5.1.2600.
My Hard drive was just checked yesterday.
I have just downloaded the latest Easy Stand Alone software from Nicolaudie's site per Adam at Nicolaudie America.
The program reads the SLESA-U5 in USB mode showing "PC" on the face w/ the red led blinking rapidly.
The Program will not allow me to drag the Generic > rgb lights from the scan library over to the DMX Universe:
I drag one over covering 1,2 & 3 but it doesn't add the .1 after rgb and when I drag the next one over, the first one disappears.
Thank you for your help.
Lawrence
Re: can't drag Generic rgb fixtures to DMX universe
Hmm I don't really understand what is going on here.
1. You drag a 3 channel RGB fixture to DMX channels 1-3 on the grid
2. You drag another to DMX channels 4-6 and the first one disappears??
That seems strange, are you sure?
Any chance you could send over a screen recording?
Does it work when entering the number of fixtures and starting dmx address and clicking patch?
Morrell
Post by Morrell »
Hello Simon,
Thanks so much for your help. I have used 3 dif progragms, all from Nicolaudie. 1st off the disk that came w/ the unit. 2 downloaded as Adam at Nicolaudie america said the first downloaded month ago was corrupted. All 3 have had the exact same result. I don't know what you mean by "entering the number of fixtures and starting dmx address and clicking patch".
I don't see this in the manual which instructs to drag and drop. Where do you:
> enter the number of fixtures?
> Start dmx address?
> click patch?
The patch I see is like "scan library" a name for an area of the program where the dmx universe shows and is not clickable.
I have included pix of the process:
1: RGB highlighted under Generic> rgb in the scan library (right before dragging)
2: dragging it over 1, 2 & 3
3: letting go and it only showing 'rgb' not 'rgb.1' like it does in Demo mode.
4: right after clicking on 'rgb' again to drag another (this is when the 1st disappears).
I have purchased 2 of these units, had them for a few years and when no one could help me, just shelved them but now we need to get our $1,000. out of them. I have spent many many hours w/ my vendor, Environmental Lights and others trying to solve this. I even hired a computer engineer who was stumped. I've Checked my computer, replaced the program, everything….Thanks again for your help.
Morrell
Post by Morrell »
oops, forgot the pix. BTW do the lighting fixtures need to be connected while setting up the program? It works fine in Demo mode, USB mode shows "PC" on the unit while running the program and red light blinks rapidly as well, so I know the unit is running/working.
perhaps direct email would be faster, [email protected]
thank you,
Lawrence
So you only have this problem when you have an interface connected?
Which product are you using? (eg...SLESA-U5, SLESA-U8, DXPACK01 etc....)
Which operating system?
The reason you can't see the manual patch objects is because you have a low resolution monitor and theobjects are being covered by the faders, drag the horizontal bar down (above the faders) to reveal.
take a look at the Easy Stand Alone getting started video tutorials here:
http://www.nicolaudie.com/nicolaudietv
OK I have found your problem.
Basically you have tried to drag across a corrupt profile which has consequently messed up the dragging and dropping in the patch window.
1. Close Easy Stand Alone
2. Download the latest Scan Library Editor, the link is at the top of the forum
3. Open your profile with the new editor (you may need to recreate your profile, sorry!)
4. Restart easy stand alone and all should be good
Wiza
Post by Wiza »
I'm experiencing the same problem here.
But as i found out it is not the lib. who is causing the problem but the USB mode.
In Demo mode it works fine.
The first time that i had this problem is when i tried to download the file from the stand alone hardware.
I then tried to write a new showfile and upload it, but the fixture does not seem to mount to the universe.
Not by dragging and dropping and not with the patch button.
I only have the problem with an laptop that runs on Windows XP Professional with SP3.
On laptops with newer versions of windows there is no problem.
greetings Walter.
Wiza
Post by Wiza »
I'm expiriencing the same problem, it only occurs in de USB mode.
When i use te program in de demo mode there is no prblem.
I tried removing the program installing an older version but the problem keeps appearing.
The biggest problem is that it's not possible to download the showfile from the hardware.
I'm using an rather old laptop ( on my new laptop it works fine )but we were using this laptop for some time now.
And never had any problems until now.
Laptop:
HP compaq NX9005
Windows XP Proffesional SP3
I'm hoping you can help me fix the problem.
With kind regard, Walter.
