Window screen management
Dojec
Post by Dojec »
If you load a new fixture group, then that window is nicely positioned asside the rest.
You can also drag it over another fixture group, so you have a tabbed windows with the different groups.
But now if you want to take out that tab from the group, your window is floating over the others.
How can I get it back in the first situation?
If you compare with office word, there you have possibilities to cascade all your screens, or put them next to each other with 1 mouseclick.
Regards.
RichterMC
Re: Window screen management
Post by RichterMC »
That´s an easy one. Left click on the window tab you like to move and hold the left mouse button down, when you start moving the window you will see some
blue icons in your screen. Move your mouse cursor over this icons and see what happens, the rest is self-explanatory.
Maybe you will need some time to get use to this, but once learned it´s easy to use and you can rearrange windows very fast.
Also learn how to use "Favorites" this is a very powerful tool to save window positions and recall them by a keyboard shortcut or since Beta 24. Sep. by a Midi trigger.
Best Gernot
Dojec
Post by Dojec »
Thanks.
I found it this afternoon. I'm just using the software since this weekend.
So it probably will take it's time before getting used to everything.
