Hi Simon,
I can´t get the new Beta to work on Windows XP.
It will crah when the splashscreen says "Loading Midi console Data".
I send in a crash report to Dylan.
On my Windows 7 64 Bit the 23Aug. Beta starts O.K.
Is there a way to force Suite 2 Software to show the "Open Show" Window at software startup,
even when it´s not enabled in the "Starting Parameters" ?
Best Gernot
23 Aug. Beta crashs on startup under WinXP
Re: 23 Aug. Beta crashs on startup under WinXP
Hi Gernot
We'll look into this.
Yes this is possible, open up the global.xml file in the datalight folder. You can change the open show dialog parameter from 0 to 1 in there.
O.K. the new 24. Aug. Beta release solved the problem on my Windows XP machine.
Best Gernot
Thanks, good to know.Yes this is possible, open up the global.xml file in the datalight folder. You can change the open show dialog parameter from 0 to 1 in there.
Best Gernot
