Beta 2 Status
Posted: Wed Aug 04, 2010 12:44 am
I have been looking for a DMX Contorller Software that will allow use in a Live Entertainment Environment. Such that if a show is running and the guitarist takes a solo - the lighting person can still change the light effects to account for the solo. In other words I would like to have the capability to trigger a scene then trigger another scene without changing the first scene. Then turn off the second scene while allowing the first to continue.
To explain another way I would like to turn as many scenes on as desired and turn them off as desired:
so pressing "r" may trigger a Red Wash of the Stage and pressing "L" will trigger lasers to the house but not change the Red Wash on the Stage.
when I press "L" again the lasers go off and I might press another trigger to change the House lighting. Or while leaving the house lighting I might press "b" to change the stage effect to a Blue Wash. Or change the stage effect to a Sound Active Macro.
Bottom line is that I need to have multiple things going on simultaneously that I can Dynamically select without turning everythong else off.
Further I need a black out feature to dim all lights between songs.
Does Sunlite Suite 2 have this type of Live Performance Capabilities?
If Yes - when will it be relatively available for live use?
