DasUsbCommand - DHC_DMXOUT speed ?
Posted: Tue Jul 06, 2010 7:36 pm
I bought a DMX controller SIUID 6C and I use the Developper SDK to use it in my software. It works pretty well, except for the fact that the call to DHC_DMXOUT sometimes takes a pretty long time. It varies around 37-38 milliseconds per call, but sometimes it goes as low as 2ms. I'm wondering if it is the normal speed, or if there's something wrong with my software. The documentation mentions something about a "stand alone mode" but I'm not sure what that means, or how do I "wake" up the DMX controller if this happens.
I did a small code snippet that reproduces the problem. I compiled it as a Windows console application with Visual Studio 2008. The driver I use is the one found on the CD that came with the DMX controller. (The one in the folder "Driver\siudi_stick_ 32_64_bit" of the CD)
Thanks for your help,
- Matt
Code: Select all
#include <conio.h>
#include <iostream>
#include <windows.h>
#include "_DasHard.h"
HMODULE mDLLHandle;
typedef int (__cdecl *PFDASUSBCOMMAND) (int, int, unsigned char *);
PFDASUSBCOMMAND DasUsbCommand;
__int64 sFrequency;
int main()
QueryPerformanceFrequency (reinterpret_cast<LARGE_INTEGER *>(&sFrequency));
mDLLHandle = LoadLibrary("DasHard2006.dll");
if(mDLLHandle)
DasUsbCommand = (PFDASUSBCOMMAND) GetProcAddress(mDLLHandle, "DasUsbCommand");
if(DasUsbCommand != NULL)
DasUsbCommand(DHC_INIT, 0, NULL);
int interfaceOpened = (DasUsbCommand(DHC_OPEN, 0, NULL) > 0);
DasUsbCommand(DHC_DMXOUTOFF, 0, NULL);
if(interfaceOpened > 0)
unsigned char buffer[512];
int i = 0;
while(true)
__int64 time1, time2;
//rand() % 256
memset(buffer, (i % 2 == 0 ? 255:0), 512);
int port = DasUsbCommand(DHC_PORTREAD, 0, NULL);
QueryPerformanceCounter (reinterpret_cast<LARGE_INTEGER *>(&time1));
DasUsbCommand(DHC_DMXOUT, 512, buffer);
QueryPerformanceCounter (reinterpret_cast<LARGE_INTEGER *>(&time2));
__int64 firstCall = time2 - time1;
char time[20];
itoa(static_cast<int>(firstCall), time, 10);
//std::string timeString(time);
printf(time);
printf(" - ");
itoa(static_cast<int>((firstCall * static_cast<__int64>(1000)) / sFrequency), time, 10);
printf(time);
printf("\n");
i++;
if(kbhit() > 0)
break;
DasUsbCommand(DHC_CLOSE, 0, NULL);
DasUsbCommand(DHC_EXIT, 0, NULL);
getch();
return 0;
- Matt
