Cycles
- New Forumor
Cycles
Will you be able to choose the point at which cycles loop back to? this could be way to position moving heads before turning on beams.
Re: Cycles
Cycles can only be looped back to the beginning, unless synchronised with a looping string of MIDI time code. There is a "light beam off" button which can be found on the ribbon bar, this will turn off the light beam of all fixtures. There is a seperate light beam off button at the top of each fixture page.
