3ds import is not working corectly!!!!
i am unable to import obgects in 3ds in the software ,but realise that these obgects are the same obgects that i have imported with no problems before ? whats happening?? its not a 3ds file problem or mesh problem so whats up with it??
- SuperMaxi Forumor
Re: 3ds import is not working corectly!!!!
Can you email the file to support@nicolaudie.com
Cordialement/Best regards
Bruno Falip
http://www.nicolaudie.com
http://www.lightingsoft.com
http://www.dmxsoft.com
Bruno Falip
Part of the 3D visualisers 3d object converter uses a tool which comes with windows. A change in operating system could cause the problem. Try converting your 3ds object to a direct x binary mesh using third party 3D object software such as 3D exploration. Alternatively as Bruno Falip said, send it over to us and we will see if we can convert the object for you.
