Hello. I'd like to have a confirmation.
In the hardware manual, [url]http://www.dmxsoft.com/manuals/?oem=SUNLITE&na=gY7[/url]
it's written:
"INPUT PORTS
To use the input ports, you must create a connection between the VDD pin and any port."
And in the easy stand alone manual about SUIDI6:
[url]http://www.dmxsoft.com/manuals/index.php?langman=en[/url]
"To use the input ports, you must create a connection between the Ground pin and the ports (see the picture below). "
ANd in the software ESA:
The picture show connection to GND.
So I'd like which one is the true one, because usually GND is not Vdd.
Thanks you for your reply.
François
INPUT port connected to Vdd or GND?
- SuperMaxi Forumor
Re: INPUT port connected to Vdd or GND?
It is VDD for the SLESA-U6, ground for the other products. I have just checked the online user manual and found the mistake. It works as described on the picture.
See the SIUDI tutorials for more information: http://www.nicolaudie.com/tutorials/siudi/
Cordialement/Best regards
Bruno Falip
http://www.lightingsoft.com
Bruno Falip
