Hi all,
There is still a bug in this beta, ==> group function controlled by midi.
making and controlling groups is no problem, but when you select a group in live mode and you wonna change a color or so controlled bij midi command doesn't work.
example:
2 buttons controlled by midi; 1 heads all white, 1 heads all bleu
All heads are white,
You select a group for the first 2 heads en en press live mode
than you press the button on your midi controller for all bleu
Normaly when controlled by the mouse only the first 2 head's go bleu en the rest stays white
But when controlled by midi nothing happens...
And,
Midi out, works in Suite 2, possible to implement in 2006? its the only feature i'm missing in 2006!!! stupid the upgrade and pay for only thad feature....
Manny greeting
Gert
Bug in beta 24 sept 09
Re: Bug in beta 24 sept 09
trouble about midi and group is in the sunlite 2006 or suite II ???
------- Dylan --------
Sorry for the late reply,
It is in the sunlite 2006,
And: Flash buttons controlled by midi is thad possibel?
when i make 2 buttons, 1 led pars bleu and 1 led pars yellow
i link bleu to a normal midi button, and i link yellow to a touch sensor midi button
When i activate bleu, they go bleu
But when i press yellow they go yellow but when i release yellow they go dark!
Manny greetings
Gert
Manny greetings
Gert
Ok when I find time to fixed the trouble about group and Midi I'll do it !!!
For the second part, you need to change the properties of your command "Button activation", you need to play with the "Type of action" and try "v>level".
Thx,
but with the flash button,
I've tryed everything, but my midi box sends out:
Note On v 127 => whene i press it
Note On v 0 => when i don't press it
maybe its thad the problem?
greetings
Gert
greetings
Gert
