CONTROL LIGHT CONVENTIONAL WITH SUNLITE
Posted: Mon Sep 21, 2009 2:11 pm
by mario
HELLO
IS THERE ANY WAY TO CONTROL OF A FILAMENT BULB LAMP NORMAL THROUGH Sunlite?
Re: CONTROL LIGHT CONVENTIONAL WITH SUNLITE
Posted: Mon Sep 21, 2009 7:25 pm
by N.Webber
This is the way...
[PC + Sunlite] ---(USB cable)---> [DMX Interface] ---(DMX cable)---> [Dimmer/s] ---(AC cable)---> [Filament Lamp]
Posted: Wed Sep 23, 2009 5:00 pm
by mario
thanks for the reply.
you elaborate? I do not understand very well!!
thanks
Posted: Wed Sep 23, 2009 5:46 pm
by N.Webber
The PC running Sunlite is connected by a USB cable to the dedicated DMX interface which generates the DMX control signal.
This DMX signal is fed to a dimmer. The dimmer sets the 'level' of voltage passing from the mains supply to the lamp.
The lamp will glow respectively of the output level of the corresponding channel in Sunlite.
Posted: Thu Sep 24, 2009 1:52 pm
by mario
I recommend buying that dimmer to connect to Sunlite? is difficult to create the library for the dimmer? I'm a bit lost!
thanks
Posted: Thu Sep 24, 2009 2:06 pm
You don't need to create a library for the dimmer, only for the lighting which is connected to the dimmer. For example if you have an 8 channel dimmer with 8 PAR56 cans. You insert 8 PAR 56 can profiles into Sunlite Suite, then on the dimmer you set the starting DMX address.
For example if the starting DMX address is 20 on the dimmer pack, you will insert your PAR can fixtures to channels 20, 21, 22, 23, 24, 25, 26 and 27 in Sunlite Suite.
