i downloaded the latest software last week, the one that was released on 30-jan.
now when i starded it and i looked around to see some changes it crashed when opening Page>arange buttons, the 3D view was on
it happend 3 times i tryed then i closed the 3D view and i dint have the crash no more.
an other ting is when programing a button to change the scan pan and tilt, it works realy slow when you select the point to change it in the right place.
so i had to install the provious version, could you please check if you have the same problem?
i am using a Sunlite suite 2004 First class on a P4 3000 whit 1024MB ram and a GF FX 5600 GO video card
thanks
matthieu
latest version
Bug in latest version
I've now downloaded the latest version, but now, there is another bug!
When you will just select a field, you must click on it and push the "Shift"-Buttom at the same time. That works perfect! But the problem is:
When I've selected a buttom / a field, I can't use the combination "Alt+P" OR "Alt+D", it doesn't work.
So I've reinstalled the older version from 1. dez., there I haven't any problems.
Best regards
Leander from Switzerland
Best regards
