Hi to all ! I'm new in this software, so I have some doubts
I want to begin excusing me for my English, I'm going to try to do the best I can.
I'm using a Geni OBY-3 250 spot and I'm currently programming offline.
When I plug in the interface, the moving head does not place in the same spot I see in the 3D view.
I have a (more or less) 5 degrees of error. In distance it matters! about 5 meters of error at 10 meters of distance.
In example: If I put the arms of the head in parallel to the base in the 3D view, the real head goes that way, but a little bit to the right.
The tilt is perfect, only ocurrs on the pan.
There is any way to change this from the library (change the dmx values only for this 2 channels (pan/pan fine)?
Or limiting the values so 127 is the actual 127 dmx value for the unit?
Thanks in advance.
Eduardo
from Argentina
Problem with positioning moving heads
- SuperMaxi Forumor
Thanks bruno, but the amplitude is OK, 570°bruno.falip wrote:You must find the PAN amplitude in degrees (should be written on the manual) of your fixture and modify it in the profile.
It seem that the 3d head is out of phase compared with the real one.
The center (DMX 127) is just a few degrees aside from where it shoul be.
Any ideas?
