next step with port
Posted: Fri Dec 12, 2003 9:58 pm
by johanspijker
Dear Sirs,
I am planning to make a little beatgiver (0-10v) that gives pulses to the input port.
Is it possible that you can change the software easy stand alone that a next step is chosen when a port is getting a pulse ?
Johan
Posted: Sat Dec 20, 2003 11:10 pm
by Eugene Sitnikov
excuse me for bad English, i'm from Russia
I think, that most better, if you connect your device not in to the input port, but to up/down keys. You must use optocouplers (MOC3020, etc): pin 1 & 2 with 360 ohm resistor (for your 10V application) and pins 4 & 6 connect with keys up/down in parallel. It's worked in my solution.
Posted: Sun Dec 21, 2003 3:58 pm
by johanspijker
But then you get up/down for the scenes, and not up/down for the steps in the scenes. But it works too.
What I want to do: choose an scene with the up/down and/or ports(1-7 for example), and sync that scene to the music( with port 8 for example)
What do you use as beatgiver ?, also a selve made circuit ?
