Can it be make possible to stop the audio analyser from disappearing i
into the tray icon, when minimized. Because you loose the alt-tab function, and also if it was minizied, then you have highlight the learning point before the F5 shortcut work again.
Suggestion for the future now that the audio analyser has got at shortcut for the learning button why not cross link the sunlight and the analyser so that you can tap the learning shortcut form inside sunligt.
From Denmark
Lars Wollsen
