I would like to know some possibility there is been of doing the transition of scenes manually in real time. for example: during the transition of a music for the other (dj), on that moment the music is only with the demarcation of the bass drum and snare, I created a scene in that moving heads 1 and 3 they light while 2 and 4 they turn off and so forth. As I can have that control of the change of the scenes in the space bar. thankful.
I use the version EC
Change scenes whit the space bar
- New Forumor
- Contact:
- Junior Forumor
Hi there!
I think the easiest way to do this is to create a Cycle using the scenes you want to step through, and then change the scene times to use the "Go" setting.
Then you can step through the scenes using the Page Up and Page Down buttons.
I use this technique a lot for syncing scene changes with live music.
Cheers, Vince
Cheers, Vince
- New Forumor
- Contact:
thanks
thanks bro... I have it.
