a question about sunlite
Hello everybody,I have a question about sunlite . i don't konw how to use the "live control",who can tell me how to set or use it .thanks.
live control
-click the power button
-there are 4 boxes in the top left under where it says "mouse". click the one with "X" underneith it
-find the channel number of the X movment of your fixture, for example, lets say this is channel 5
-click the box below the number 5
-do the same with the box above "Y" and assign to the Y movement channels
-if your fixture supports 16 bit movement you can assign uX and uY buttons to the 16 bit x and y channels
-you can assign the x and y buttons to as many channels as you wish
-save the button
-make sure you have the shutter and dimmer channels are activated or your lights will move and you wont see anything
hope that makes sense, let me know if you have any problems
simon
-save the button
simon
I'm sorry, sir
and save it,but what should i do the next ? Because i don't know how to control my "moving head" in live control ,that's to say, what's the function of the "live control" ? Thank you
LiveControl
Create a new page with the Scanlibrary wizard. In step 2/9 you are asked for shortcuts. The wizard suggests a shortcut key for every fixture.
Finish the wizard.
In your new page you then have a Scene called 'X-Y'. Here you see the shortcuts again. Just press and hold the shortcut key(s) and you can control the fixtures 'live' with the mouse.
Finish the wizard.
