Customizing Gobos
Dizzo007
Customizing Gobos
Post by Dizzo007 »
:?: Can the gobos be customized on the Viewer to reflect what the actual gobo is instead of an open spot with the Gobo Number indicated. I am runing American DJ Performance Scan 250 and the gobos are not showing correctly on the viewer. This doesnt give a good idea as to what you are actually doing versus what will show when the actual lighting system is hooked up. Same issue with Martin MiniMac Profile.
Please help... :?: Thanks
Guest
Post by Guest »
Please send a picture of the gobo and the name of the profile to support@nicolaudie.com
We will have someone to modify the profile for you as the gobo editor is not finished.
kvm
Post by kvm »
Anonymous wrote:We will have someone to modify the profile for you as the gobo editor is not finished.
When can we acpect the gobo editor?
I only want to change (or add) some gobo buttons.
Because it's a laser unit it is not nessesary to see the beams in 3D.
Martin.
Post by bruno.falip »
We don't know at the moment.
