Control DE3 over IP
The star of the STICK family.
fremlingen
Re: Control DE3 over IP
Post by fremlingen »
Hi!
You posted that you needed to update the documentation to reflect the changes you made to only accept UDP connections,
but it seems you still haven't done that. Can you find some time to do actually do that? And are there any more changes that
hasn't made it to the documentation? Can you now receive status messages from the stick-DE3 over UDP even though TCP was used for this earlier?
nick wrote: Thu Dec 20, 2018 4:56 pm Hi there,
Unfortunately with the Stick-DE3 firmware 2.1, the remote protocol no longer supports TCP packets. You must use UDP packets on port 2430 instead.
We need to update the documentation to reflect this. The last firmware that supported TCP remote protocol was 1.13.
Hey,
As Nick said, the remote protocol no longer supports TCP packets. You must use UDP packets on port 2430 instead.
