Making a breathing effect
ESA Pro 2.1 is the latest iteration of the famous ESA Pro lighting control software & brings a whole host of new features and improvements including: streamlined workflow, updated user interface, control for electrical relays, DALI support, LED Pixel support and new T-C-A triggering options.
Wibs
Post by Wibs »
I am trying to make a breathe in/out effect.
In theory, I could make this by manually adding points to the basic block's generic dimmer property and selecting the fade in/out curves I think work the best, but this seems like a lot of work and also, if I adjust the length of the timeline, I would have to manually drag the points into new positions. I understand that this is because the points are time-based, not % of the timeline based.
Since there is no "hold orthogonal" button, I can by accident change the value of the dimmer while dragging and would have to re-adjust this.
This also does not work for the pre-set effects - e.g. rainbow
Any suggestions?
Re: Making a breathing effect
You might find interest in the "custom loop" option, which would allow you to force the amount of times the block loops on itself, regardless of its duration.
If you only want the block to loop once, no matter what final duration you chose to give it, check the "custom loop" option, and make sure it only loops once.
Hope this helps.
