Goodmorning I've bought the Sunlite Suite and now I use it for a Musical. So, I'd like to make the scene before the show.
So I'd like to know if I make the switch with the position of the moving head and I use these switches for some scenes, if I edit the switch also the scenes will edit, like the palette that are in a lot of console.
Angelo
Scenes edit
So, basically you are asking: if you include a switch in a scene and decide to edit the switch afterwards, will the scene which was created using that switch change accordingly?
as far as i know - i'm pretty sure: it does not. the memory of a scene will not be affected in any way if you are messing around with switches as long as you do not store any new commands into that scene.
greetings,
jan
greetings,
jan
