Hi:
I want to create a Roller scan in scanlibrary and I select the roller scan to define the type of scan (roller).
I defined the channels, presets etc.. but still in the 3d show window appear a single head scanner.
Anyone know how to cretae a Roller scan that could appear in the 3d window and also roll the lights?
Walter
Creating a Roller scan in Scanlibrary (ssl2)
Re: Creating a Roller scan in Scanlibrary (ssl2)
Hi Walter. The 3D can only create single beam and prism effects.
Thanks Simon for your reply
I don´t understand why then in the library editor is the alternative to select a Roller scan if it is not possible to show it in the 3D window.¿?
is a bug or will be implemented soon?
regards
Walter
regards
Walter
The reason it is like this in the library editor is to future proof the profiles. There are many other effects available in the library editor which cannot be visualised. SSL profiles are only updated every 10 years so we need to make sure that we have thought about all options.
