After uploading to firmware 1.07 the USB SIUDIC 8C it is not working now.
With firmware 1.04 was working without problems.
In have tried several times the upload firMware process but is not possible because I recieve a message "upload fail!"
The red flashing light is permanent red or in some cases off. The usb light in some cases is on (flashing) but in others flashing.
can I return to the previous firmware?
walter D.
problems with SIUDI 8C new firmware 1.07
Re: problems with SIUDI 8C new firmware 1.07
There appears to be a bug in the firmware.
Re-download Suite 2 tomorrow and there will be a new version of tools.exe.
It should let you update the firmware. Let me know if you have any trouble
Thanks for your replay, I will do this in the weekend.
A question: A new firmware version was issued (othar than 1.07) , or this new tools.exe application will allow me to install the old version?
Regards
walter D.
Regards
walter D.
Installing an old version is not possible
Thanks for your replay.
Should I download the Nov 25th Sunlite 2 version? or I have to wait for a newone?
Regards
walter D.
Regards
walter D.
Download the latest (Dec3). This is the most stable
