If you add new fixtures, then you open the patch window. Now the pull down menu's for selecting 'dmx universe',' first dmx channel', and 'number of' displays an up/down arrow on that pull down. This is misleading me as I always press that upper arrow to increase the number. And if you click it's just a pull down menu, so to be correct, it should only show a down error on those menu's.
Regards.
Wrong arrows while patching
Re: Wrong arrows while patching
Actually it uses the Mac style pulldown graphic which contains 2 arrows as opposed to the PC style graphic which just uses the down arrow.
I don't see this as an issue but if I have other complains we'll see about changing the graphic.
It's indeed a minor feature, but everytime I open that I click the upper arrow, then realising it doesn't work ;-)
