how do i go into stand alone mode for suite program? im using suite2-fc.
please advice
Suite stand alone mode
Re: Suite stand alone mode
Hi Calvin
You need to use the Easy Stand Alone software. Sunlite Suite doesn't support stand alone directly (however suite 2 will when it is released).
You can import an easy step button from Sunlite by selecting "import" in the editor screen of Easy Stand Alone (to the left of play)
Hi Simon
Where is the function to export the easy step button to ESA? i was not able to locate it.
Thanks in advance
Thanks in advance
You don't have to export the button from Sunlite Suite as every button you create in Suite is saved in a separate file.
1.Make sure you have the show loaded in Sunlite Suite
2.Got to easy stand alone, select import
3.Navigate to My computer->c:/(or your partition where suite is instaled)->SL2006->light data->the page where your button is
4. You should then see all the buttons you have created with easy step and should be able to import these
