bouton flash sur bcf 2000
VJ-CrashOverDrive
Re: bouton flash sur bcf 2000
Post by VJ-CrashOverDrive »
Tu dois mettre la touche en toggle OFF
-Edit + touche
-7ieme Rotary sur la console tourner sens anti-horaire jusqua que tu vois t off
-N'oublie pas s tore ton setting apres
Shoot to Lives !
AlainKebraRenard
Post by AlainKebraRenard »
Système Sunlite Suite avec BCF2000 et Touch Screen ELO 1515 , boitier 2048 ch St A et basic 512 ch.
AlainKebraRenard
et donc c'est plutot ça...
* Report this post
* Reply with quote
Re: behringer buttons
Postby N.Webber on Thu May 07, 2009 11:24 am
You need to edit the button's 'Toggle On/Off' parameter.
While pressing the Edit button, click on the related button.
This puts you into edit mode for that button.
Rotate encoder No. 6 until the display reads T - Off.
Click the Edit button to exit edit mode and then the Save button to save the change.
As simple as that...
P.S. It's all in the manual...
N.W.
