2nd universe on SUITE2FC box doesn't work with ESA software
robymilani
Post by robymilani » Thu Sep 16, 2010 11:55 am
hi all!!!
i have a problem: using ESA software and SUITE2FC box (slesa u7 i think).. i can't run anything on 2nd dmx universe!!! i have made a correct program.. but i can't see anything out by the 5 pin connector... is it an incompatibility between ESA and SUITE2FC BOX?? or is it a bug??
Re: 2nd universe on SUITE2FC box doesn't work with ESA software
Post by simonB » Thu Sep 16, 2010 12:17 pm
The Suite2-FC and SLESA-U7 boxes support 2 DMX universes in Stand Alone, however Easy Stand Alone only supports up to 512 channels in Live mode.
I understand that maybe this is not very clear in the documentation, I will see if we can have this changed.
robymilani
Post by robymilani » Thu Sep 16, 2010 1:23 pm
hi simon thanks for your fast answer...
you told about LIVE... but if i set 2 universe and run the box in STANDALONE does they run both?
Post by simonB » Sun Sep 19, 2010 4:11 pm
Yes this should work find in stand alone
