yap
Post
by yap » Wed Sep 24, 2008 8:08 am
Currently, I am doing a project which involved lightings. I tried using Easy Stand Alone software and Lumidrives Colourdriver 36 to control the RGB lights. However, I faced a problem. Whenever I switch on the power, the lights will always on and i can only control the brightness and the colour of the lights. But, I can't off the lights using the software. What to do??? Is it because of the Lumidrives colourdriver or the software???
yap
Post
by yap » Thu Sep 25, 2008 5:21 am
anyone can help to solve the problem? i really need it urgently...
- SuperMaxi Forumor
Post
by bruno.falip » Thu Sep 25, 2008 7:19 am
If they are RGB drivers then you juste need to select black (all channels to 0). If it doesn't work then it is a diffrent problem and it does not come from our software.
yap
Post
by yap » Thu Sep 25, 2008 9:35 am
Thanks a lot for your reply. Since there is no problem with the software, is there a need to set the Lumidrives Colourdriver 36 's DMX address in order to off the LEDs?
yap
Post
by yap » Fri Sep 26, 2008 3:48 am
anyway, I tried using white colour LEDs... It actually can be turn off when the RGB is tuned to black. But when i try the RGB LEDs, it cannot be off when the RGB is tuned to black. Why is it so?
