SIUDI 2 Green LED does not blink.
*DISCONTINUED* SLESA - SL512EC - SL512BC - SLMEV
olivier085
Post by olivier085 »
I have a SIUDI2 interface that I used to run with Magic 3D easy viewer. But now I don't understand, the box is seen by windows, no problem, I install the drivers without issue, I launch Magic3D and he sees the interface, DMX is ON on the right bottom of the screen, but when I try to control the Software, nothing happens, and the green LED does not blink. What's happening ?
Re: SIUDI 2 Green LED does not blink.
We have fixed this issue this morning. Download the latest release and it should work fine.
olivier085
I downloaded the latest beta version, but it doesn't change anything. When does normally the green led blinks ? When I launch Magic3D ? when the usb box is plugged ? Could there be a problem with the box ? Do I have to use specific drivers (I used siudi driver.zip) ?
Sorry for all these questions...
Sorry for the late reply. Did you try the latest siudi driver?
If you are still having trouble getting the box to work:
-Have you tried on different machines?
-Which operating system are you using?
-Right click my computer and navigate to the device manager, is it installed correctly or does it have a "!"
If the driver has been installed correctly, the green LED should be static when you are using MEV.
