bought a complete lightset (8scans,pars etc..) and a laptop with sunlite 2004 (15 apr 2004 stamped on cd) and a sl512ec, box is fluorenscent green
I connect the dongle, and installed driver and 2004 version of sunlite
the yellow led is on the red is blinking fast, the green blinks sometimes
is this right ?
than I conect only 1, 4ch. dimmerpack, make a simple scene but nothing happens..??
when I start up sl I see that the software reconizes the dongle.
tried out different sl versions with no succes.
also checked firmware, this was already up-to-date...
another hardware question
there is an empty 8dip socket on the pcb, on the other site there is an smd part, I read somewere around this forum, if you have problems replace the ic in this socket....???
does it needs an ic ? if so what type ?
another question, where are the 2 buttons for on the dongle ?
pse help, this whole dongle thing is making me crazy
need help with sl512ec
- SuperMaxi Forumor
tnx for the reply
I installed the easy stand alone from cd, the software reconizes the dongle but still nothing on the output....
I have dmx output (checked with scope)
but I checked a few things, one of them is that the output dmx voltage is low about 2.3 volt max.
and this is to low for ttl switching.
if I check my other dongles and my dmx table then this is about 5volt...
I thing this voltage is to low so I'm going to build a dmx booster and see if this is the problem...
the constuction of this dongle is a bit wierd, the output ic is working on 3.3volt, al the other dmx stuff I have this is 5volt and the output ic is an 75176, the smd on the sl is similar but only for 3.3volts...???
how you people get this dongle to work ?
let you know.....
let you know.....
yep.... got it to work via the dmx booster......
all my scans, par-leds and powerpacks are function like it should be.
and... they way I made it, it's now also secured (no direct connection) with the pc...
used parts 2n137 opto-coupler / nme0505 dc-dc converter / sn75176
and an 78L05
more info email me for schematic.....or use google
and an 78L05
