DHC_DMXCODE
*DISCONTINUED* SLESA - SL512EC - SL512BC - SLMEV
eLeMenCy
DHC_DMXCODE
Post by eLeMenCy »
on the Doc it is said that DHC_DMXCODE enables to change the start code.
When using this function with ie. a Slesa-U5, which port is actually affected, the OUT port, the IN port or both?
Thanks in advance
eLeMenCy
Post by eLeMenCy »
bump
julien
Post by julien »
It's the OUT port
eLeMenCy
Post by eLeMenCy »
Thank you for your answer.
So on a SLESA-U5 if the IN port has been set to OUT, does the DHC_DMXCODE command changes the start code on both ports or only on the default OUT port?
Thanks again in advance.
julien
Post by julien »
Only the OUT port.
